grizzzman
Apr 20, 2019Explorer
191124x7 wrote:
I’m not sure I understand REDARC’s answer; but the gist of it is, hooking the WFCO to the REDARC won’t work. So I’m going to let it be for sure.
Here is their answer:
“If you connect the WFCO only to the input of the BCDC1240D, this will not work.
The BCDC1240D is looking for battery voltage, and the WFCO is looking for a voltage in order to supply power – the BCDC1240D does not have battery voltage on the input without a battery connected.
If you had both the truck and the WFCO on the input, the BCDC1240D would turn on under normal voltage thresholds once the truck reached 13.2V, and start drawing the current required to charge the auxiliary battery.
If the WFCO could keep up with the current requirements to charge the truck battery, and sustain amperage required to charge the auxiliary battery, this would work just fine.”
There full of "banther podo" from the WFCO site.
Does the converter need a battery to operate?
No. The battery works in conjunction with the converter to supply DC power to the RV. A battery is typically only necessary if you do a lot of dry camping or have slide-outs and/or a leveling system.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 18, 2026
