191124x7's avatar
191124x7
Can I run my WFCO output to a REDARC BCDC?
My 2019 Brookstone 395RL currently has a: WFCO WF-9875 75 AMP POWER DECKMOUNT CONVERTER - 55-4708
I'm in the process of adding a REDARC BCDC1240D... and running #2 AWG from my 2019 F-350 DRW's battery (I have the dual extra heavy duty alternators); and plan to connect it to the battery side of the BCDC.
Additionally I'm installing 960W of solar panels on top of the rig.
All of this will be charging 400ah (4 100's in parallel) AGM batteries.
I'm sorry this is kind of a complex question, but here it is in parts...
1. REDARC says that it is 'best' if the WFCO is not in the game. That the BCDC and WFCO might sense each other's voltage and force each other into float mode.
2. So if I shut off the WFCO at the circuit breaker, I'm assuming all is well... as long as there is sufficient sunlight to keep the batteries going and/or the truck is plugged in and running.
3. However, if I'm under trees and in clouds, and the truck is off, I will eventually run out of battery power. So in that case I'd like to turn on the WFCO... and shut off the BCDC input to the battery.
4. My first idea was a DC transfer switch; but I can't find one.
5. So my next idea was... what if I take the output of the WFCO and feed it ONLY and DIRECTLY into the DC input on the BCDC?
Finally my questions:
- I guess the first question is... will this even work? Like, am I right back in the same boat where the WFCO will go into float mode sensing the voltage from the solar/truck? But at this point do I even care because if it does, the sun/truck are charging... and if the sun/truck are not charging then the WFCO would come back up to 'bulk' and charge the batteries through the BCDC?
- second question is, with live power coming from the WFCO and the TRUCK/SOLAR at the same time (wired together at the DC input of the BCDC), will everything play nice, or will something burn up or catch on fire?
- third question is: Am I missing something and this is either not an issue, or is there a better way to solve it?
Thanks!
Bob
  • if the battery is low, the units will not be able to float and charging will commence, alot of people parallel chargers, which ever has higher voltage will take the brunt of the charger.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I think it would br better to feed
    Alter to REDARC
    Solar to REDARC
    WFCO to Battery
    REDARC to battery.
    As you surmised you can shut the WFCO off if you wish.
    DC transfer switches do exist.. Or you can home brew. ONly need 2 or 3 parts
    The circuit
    Two sources one is the "optional" one is the Default
    Default============= Relay NC contact
    Optional---C---Diode----Relay NO contact
    Relay coil between Optional (Point c) and ground.
    Relay moving contact----- Battery
    NOTE diode must be big enough to pass all the current and optional source must be adjusted to overcome diode forward bias drop (about 2 volts higher)
Having RV issues? Connect with others who have been in your shoes.24,305 PostsLatest Activity: Aug 28, 2025
