time2roll
Mar 16, 2015Nomad
You can 'see' the charge with a voltmeter. 12.5+ good, 12.0 or less bad or needs a charge.
Once running the alternator should begin charging all batteries. But this could take many hours. Best to get the RV someplace where you can plug in. If it has an onboard generator you might get that started and let it run a couple hours.
The 12 Volt Side of Life
