- pianotunaNomad IIILi are unforgiving. It behooves the end user to follow directions from the particular maker "to the letter", if they want long life.
Unfortunately they do not meet my needs--and the one Li chemistry that would work is a best fit with a 48 volt house battery. I'll struggle along with what I have, for now. - 3_tonsExplorer IIIPT says, “Li’s are unforgiving. It behooves the end user to follow directions from the particular maker "to the letter", if they want long life.
Since your opinion is unqualified (as a non-experienced LPF user, and ardent SiO2 campaigner), while this is the second link you’ve ‘cherry picked’, in an attempt to muddle authentic LFP discourse (very sad…), for the larger audience perhaps you might reconsider these attempted misleading errant crusades??
3 tons - RickLightExplorer IIIModern retail LFP have BMS built in.
If I lose 10% life I'm still 30-40% ahead.
This discussion is a tempest in a tea pot! pianotuna wrote:
Actually the BMS should protect if set up properly. Very little the user can do that is unforgiveable.
Li are unforgiving. It behooves the end user to follow directions from the particular maker "to the letter", if they want long life..
The link at the top is a poor reference to anything to do with LFP batteries.- pianotunaNomad III"if it is set up properly" That's the rub. How do folks know what they don't know?
pianotuna wrote:
Verify the warranty and send it in for exchange.
Typical deep cycle FLA is one year warranty, LFP is often five year warranty. That is 5x the life right there.- StirCrazyModerator
which is the same for any battery type. even your self proclamed best chemistry type that you don't own. they are probably even more fussy than LFP, but they will give you some power at -40 so they work for you.
aside from setting up my solar charger with custom charge levels and cutoffs (took me 3 min, ok 5, had to reconfigure my bluetooth controler on my renogy) I have treated it like a plug and forget battery and it has preformed wonderful. I think the only thing I dont do is plug it in when I get home, just let the solar take care of that and the only different thing Ill do is I may take the battery out when I winterize and put it in the heated garage, don't need to in my climate but heck why not its only 44ish lbs for 300ah instead of the 180lbs of wet cells. - 3_tonsExplorer IIIIt’s not clear to me what might set someone off where one opts to engage in such forum mischief, but oddly such ‘self-serving endeavors’ do exist…
3 tons
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
