opnspaces
Apr 23, 2022Navigator III
Thanks BruceMC I think I followed what you were suggesting but I'm not sure if it will work. I tried to draw out what you said. Can you see if I got it right in the picture below. If I have it right I have two questions.
1) I wasn't sure of the blocking diode position so I added two diodes. Were you saying to put in position A or position B or does it not matter and either position would work?
2) Would the 5v through the constant duty solenoid cause the starter to constantly crank. I'm not sure if 5v would be enough to energize the starter solenoid but it's a thought.
Thanks for your thoughts on this
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
