opnspaces
Apr 23, 2022Navigator III
wa8yxm--Thanks for your thoughts, I'm still reading it over and making sure I think that I understand it.
On the reed relay are you basically suggesting a much less restrictive relay to be able to more effectively pass the 5v sense signal through?
Also I do know that the Neutral park switch does not go to ground. It's a simple through switch so I unfortunately don't have the option to use it for a ground.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
