CA_Traveler
Apr 24, 2022Explorer III
opnspaces wrote:
This is pre OBD2 so when pulling codes with the engine running it goes through various computer checks including automatically revving the engine up.
Any circuit that allows the computer to rev the engine when the car is running and shifted to neutral from drive seems underdesirable. Since it's not known what the comuter does based on the 2 wires and other inputs there could be other issues. I still favor a switch, maybe a double pole one that would active a light inside when on?
OP Your last diagram will cause the new 5V relay to have 12V+ on the coil due to the much lower resistance of the starter solenoid. Not desirable.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
