opnspaces's avatar
opnspaces
Navigator III
Apr 22, 2022
Can someone help design a 5 volt circuit
Yes I realize this is an RV forum but the post is related to wiring on my tow vehicle. I have a diagram below of what I am trying to do. But I will spell it out as best as I can first. My hope is that a EE or very knowledgeable person can look at my two diagrams and tell me if the bottom one will work or why I'm just nuts.
The vehicle is a 1977 ford with c4 transmission that has a 93 fuel injected motor. This is basically all 1977 technology with simple on/off mechanical switches. The existing starter circuit has a neutral safety switch. When I turn the key to start a 12 volt start signal goes to the neutral safety switch. If the vehicle is in park the switch lets the signal through to the starter solenoid. This is currently working fine (top box below)
The vehicle also has an EFI computer that when the key is in the run position it tries to send a 5 volt signal out to the neutral switch. In theory if the transmission is in park the 5 volts comes back to the computer and will allow me to pull engine trouble codes. This is currently not working as the wires are cut.
The system has worked this way for 20 years, but I'm finally wanting to improve it. I need to figure out how to marry a 5 volt key on system with a 12 volt start system without feeding 12 volts into the computer and possibly burning it up.
The second box below is my thoughts on inserting a 5 volt relay into the starter circuit to separate the two signals (5 volt and 12 volt). With the key in the run position the 5 v relay is energized to allow the 12v start signal through.
My initial questions are
Will the computer still see 5 volts returned after going through the wiring in the 5 volt relay? Or does the relay wiring drop the voltage to 0?
Is there and easier way to do what I'm thinking maybe with diodes so that the computer knows when the transmission is in park?
The top box is the existing system. The bottom box is my proposed system. Any thoughts?
  • That lead from the ignition switch to neutral/park switch is energized ONLY when the key is at Start. This won't help for your use-case.
    You'll need to pick off the Run lead, not the Start lead.
    Put a small continuous duty relay on the Run lead, and wire it as follows:
    Coil:
    Positive: Run
    Negative: Ground
    Switch:
    Common: 5V source
    NO*: 5V sense
    *NO - Normally Open (when the relay is not energized)
    Now the 5V circuit is closed when in Run mode.
    If you want to open the circuit when the transmission is not in park/neutral, then wire the negative coil wire to the start line between the key and the neutral safety switch, AND add a blocking diode between the coil and Run line.
    Now, when the key is in Start, 12V+ will be on the coil negative line, as will be on the coil positive side from the Run line. The diode prevents 12V+ from back-feeding the run line.
    Wire the diode as follows: Run -->|-- Start (in my best ascii graphics).
    When in Run mode, and in parK/neutral, then the coil will pick up the ground through the neutral safety switch, and the starter solenoid.
    Good luck!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I disagree with JK Wilson the line you mark 5 volt return is in fact Sense. not return... Now. I do not know the specs on that computer but. have the following suggestions.
    The relay.. use a very low current pilot relay (like a reed relay) and if needed a second relay .. the 12 volt from this relay does not go to the starter but the starter solenoid.
    The "low" end of the relay goes to ground. not to the 5 volt return
    The 5 volt return goes to the 5 volt side of the relay.
    The reason for this is it is not a 'return' it's a 'sense'
    IF this does not work you are 2 wires from the plan you purpose so its' an easy switch.
    you may fnd the N/P switch goes to ground already.. If so simply move it in the circuit to the ground side of the relay
  • What I would fear is that the five volts out of the computer may have a delay time before the five volts are available. That would cause the safety switch not to de-energize when it needs to keep the starter from turning.
    Another question is, where and when does the computer get its power. The five volts may not be available when it is needed.
    Just having a box diagram for the computer does not tell what the computer is doing, and how it does it. It is not possible for anyone to answer your question with the information given.
  • Thanks for the replies, I really do appreciate the thoughts and I am listening. Here's what I do know.
    As far the computer 5v out and in wires...
    This is pre OBD2 so when pulling codes with the engine running it goes through various computer checks including automatically revving the engine up. If I forget to twist the two computer wires together the computer does not see a neutral signal and it will just sit at idle. It will not rev the engine, and will not spit out codes. When I twist the wires together it goes through the checks, revs the engine and spits out the codes. So my relay idea is to just make a fancier switch to twist the two wires together. But I was unsure of the effects of the wires inside the relay.
    I do agree with jkwilson and could run a switch that just puts the two wires together whenever I want to pull codes. In fact that's exactly what I almost did last week. But then my brain started churning to see if I could make it better. I am probably going to take that safer route and just run a switch, but wanted to get some thoughts and ideas first.
    For the record this is the relay I was thinking about using. This extra relay only has to power the starter solenoid through the existing 16g wire. Link
    What I am hearing from all of you though is that I will probably get a voltage drop and the 5 volts might not be strong enough to trigger the relay. This is really what I wanted to hear or maybe not want to hear but what I needed to hear. I definitely need to do some more thinking on this.
    I welcome any additional feedback positive or negative that you might have.
    Thanks
  • I will simply echo the above. Without knowing the capabilities of the 5 v out and 5 v return and the intended design function of those there is a definite risk to your computer in connecting anything to those points. I would be surprised if it could provide enough current to energize a relay of any size.
  • My advice is to do nothing until you can get full analysis on what/how the computer circuit is suppose to work, perhaps someone knows. And you certainly don't want to damage the computer.
    FYI There will be a voltage drop across any relay coil in order to engage it.
    X2 jkwilson
  • A return is generally the negative terminal of the power source, not where power goes into something, so I’m not sure what you are trying to accomplish.
    If you need to feed the 5V out to what you have labelled 5V return ( which I would not do unless you are certain that’s how it works) just put a switch between them and turn it on when you need it.
    For the circuit you have drawn to work, the 5V return would need to be the negative output of the 5V supply, but your circuit won’t do anything. Since you have no info about the rated power output of the computer or the coil resistance of the relay, it might burn up the computer
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
