StirCrazy
Jul 25, 2021Moderator
pianotuna wrote:
If I could find a true cold weather Li at an identical or lower cost per cycle as SiO2 I would consider it. But that means it needs to be usable without heaters at -40. So far that is only Lithium Titinate--at about 4 times the cost per cycle. SiO2 are a better choice for me.
I think I found one for you. albetra li makes a extreem version that has an added feature, if the batteries are below a spicifc temp the charging current will be re-routed to an internal heater untill the batteries are warm enough and then they will charge.
sorry didnt see the "with out heaters", I just thought that this is a neet way to do it as it is all automatic and doesnt use the actual battery power to warm them up.
Steve
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
