pianotuna
Feb 23, 2015Nomad III
Hi Phil,
My air conditioner fan only setting draws 225 watts. I can NOT recommend a "suicide cord" approach.
I would pick up the DC at or in the power distribution center.
pnichols wrote:pianotuna wrote:
I found out I could keep my class C cool through out by running the roof air on fan only.
Don,
That's an outstanding suggestion!
I wonder if my A/C's ducted fan system will run off our mobile (not built in) 300 watt inverter?
I built a cable for it with a 120V plug on each end so as to backfeed the inverter's output into any of the coach's 120V receptacles without having to use the shore cable, but I don't know where I'd plug the inverter's 12V input cable to get 30 amps of DC while going down the road?
