- MrWizardModeratorThe cable is only between the phone and the tv
It is still cellular data over the cell net work, to get to your phone
If you drive your car in the city streets and not on the interstate
It still burns gasoline
There are two issues at work here
And that is how your data is allotted by your cell plan
Amount allotted via phone display use
And limited via hotspot use
Everything you do on the phone uses data
Every text, every picture, every weather report, every app, every email
With today's 4glte . Phones even voice phone calls use data, it's just counted as minutes instead of data
If you have a surplus of 'phone display data'
You want to use that instead of the limited hotspot data
If you have a limited data total, instead of phone display surplus
Going via cable does not help you
More and more phone plans have large to near unlimited 'on phone data allowance' or some kind of video service included
And limited hotspot data allowance
So sending the phone display to a larger screen aka TV, avoids using the hotspot data, it still uses data just not the limited hotspot allowance
In brief , cabling may allow you to shift the data use to the part of your plan that is not so limited
Depends on the plan and what you are cabling Tom_M wrote:
You can, but you will still be using the same amount of data.
If you are sending the data over a cable, not over the airwaves, how it is possible consume data on your cell phone plan?- rjsurferExplorer
MrWizard wrote:
in most cases, FoxFi does not use the phones built in hotspot app
on the samsung S-5 , it sets up a VPN style situation in the phone
that masks the data as phone use data, instead of showing as Hotspot data
the key here is too use a third party APP (there are several) and Not the built in hotspot feature provided by your carrier, which identifies the data usage
As you mentioned they maintain a net server that acts as a VPN. A few years ago they went down and there was a lot of unhappy people, Foxfi users thought Verizon had somehow compromised the Ap but finally Foxfi owned up to there issue.
Ron - MrWizardModeratorin most cases, FoxFi does not use the phones built in hotspot app
the key here is too use a third party APP (there are several) and Not the built in hotspot feature provided by your carrier, which identifies the data usage - beemerphile1ExplorerI'm curious how the provider knows if the phone is streaming or working as a hot spot.
I have Total Wireless which forbids using your phone as a hot spot yet I do on a rare occasion. Not to watch tv but to do banking on the Chromebook. - rjsurferExplorerOP back,
Ok, a solution! I forgot about Foxfi, that Ap will allow my wife's cell phone (Galaxy S-5) to run as a Hot Spot undetected over any network. So no more worries about going over Hot Spot limit. I can have Roku or Chromecast working on that local network, no restrictions. I haven't used it in a year or so but it fired right up
And worked like a charm.
The only problem with foxFi is its limited range of cell phones and networks it will work on, you can root around their web site and get the list. If memory serves me correct none of the later phones will work, cell networks got wise to it's operation.
Ron - GordonThreeExplorer
rjsurfer wrote:
OP back,
Just checked advanced specs on the phone and the mini USB doesn't have video out....which I'm assuming is necessary to get video through a HDMI cable to TV.
Ron W.
Looks like that K20 is pretty locked down. Both HDMI output, called SlimPort, and screen mirroring (casting) called Miracast or SmartScreen are disabled on the phone. - MrWizardModeratorknowing and understanding are not always the same thing
if he is hotspoting the Roku , he is not 'streaming' on the phone
this is the key 'factor' to the situation
watching phone video stream on the TV is 'casting' or 'mirroring'
watching a roku channel using the phone as a wifi hotspot is entirely different
cabling a roku ? to the phone is not going to reduce the amount of data used to watch an HD video stream
if he is using the roku to watch Hulu
he can use the hulu app on his phone to watch a 480p stream at reduced data useage and 'cast' that to the TV with an adapter at the TV
is there a roku app ? for phones ? which might help
his phone plan is a key in this situation
and the only thing he has said is that he has a 15gig hotspot data useage, and he is trying to eliminate hotspot useage
if he has unlimted 'on phone' no hotspot use
he needs to stop using the roku, and stream it on the phone - rjsurferExplorerOP back,
Ron W. - GordonThreeExplorerWhy does everyone assume the OP doesn't know how his mobile plan works? The data is data argument doesn't hold true for every carrier and every plan.
My carrier AT&T somehow keeps track of how much hotspot (tethering) data I use, and how much mobile data I use, on the same phone. I assume they track MAC address but not 100‰ sure.
After 15gb on my hotspot I get a warning text message that my service may be slowed down but doesn't get slowed down. (Yet)
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
