MrWizard
Jun 15, 2015Moderator
SCVJeff wrote:
I wouldn't... An solar controller is designed to regulate or boost ultra clean DC, not the junk that comes off of all chargers. Even the good ones arent anywhere near as clean as a panel. Who knows what might be damaged.
that is the correct answer
besides you would need an expensive heavy duty solar controller to handle converter amps
also solar controller reduce voltage to increase amps,
don't know of any controller that will take 13.6 and make it 14+ volts
even MPPT go down from 20+ to 14.6 not convert up aka BOOST voltage
nope.. converter goes to battery Not thru solar controller
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
