Gdetrailer
Dec 12, 2021Explorer III
If it is physically the same dimensions (H x W x D) then it should fit without any needs to modify the opening.
May or may not need to modify the plumbing depending on if they changed locations of the connections between the two but even that is pretty easy to fix.
Get the dimensions and check those against what you have..
$100 deal, I would jump on that if I had that chance, although I am used to manual pilot light water heaters, they don't bother me.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
