jaycocreek's avatar
jaycocreek
Explorer II
Jul 17, 2022
Can you use all terminals in parallel connection?
Not much of an electrical guy myself so I thought I would ask if you can use all the terminals in a parallel connected battery..Ofcourse one positive off of one battery and one negative off the other goes to the coach or load but can the other two be used for say charging?
As shown in the picture,the two center positive and negative terminals..Can these be used for charging or say accessories?
  • joebedford wrote:
    This is what I have for multiple loads off the battery. The bus bar is full now - last slot used by breaker for inverter.
    link to this item?
  • The experts say you can but why not get a larger bus bar?
  • Balanced connections are even more important for these batteries with very low internal resistance and flat voltage discharge curve.
    Get the bus and clean it up.
  • This is what I have for multiple loads off the battery. The bus bar is full now - last slot used by breaker for inverter.
  • I have it wired as shown above for all loads as of now,I'm wanting to just charge with alligator clips or ad another accessory without using the already almost full, positive and negative post..I guess a bus bar is in order...
    Thanks
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Short answer is you may yes.
    Now on very heavy amp devices.. Like a 2000 watt inverter.. Wire as shown above.. Even a large converter (say 50 amps or more) likewise.
    But for most loads.. like phone chargers which typically draw in the single amps range.. No problem at all.
