- DAS26milesExplorer IIOk, out at the beach camping with my brother. Put the kill-a-watt on directly to inverter and turned on microwave. He was shocked to see 1500-1550 watts. We did a bunch of other testing, but bottom line is microwave exceeds power limits of inverter. He will get a 2000w.
- pianotunaNomad III
JimK-NY wrote:
It sounds like the brother is going to use the generator to charge the batteries and then use an inverter to use the battery power for the microwave. Bad idea. Use the generator solely for the microwave by hooking it to the RV's 110 service.
Many of us do just that. If I stop for lunch I don't want to be deploying the generator. - JimK-NYExplorer II
DAS26miles wrote:
My brother has a High Point microwave 900w with 1350w operating. He says the inverter won't run the microwave even on a totally isolated circuit. Starts then stops. Now he is worried that his Hoinda 2200i generator may not have enough power either. He has major trips coming up and wants to get the microwave working off shore power.
The Honda should have plenty of power to run the microwave without any additional loads. It sounds like the brother is going to use the generator to charge the batteries and then use an inverter to use the battery power for the microwave. Bad idea. Use the generator solely for the microwave by hooking it to the RV's 110 service. - wa8yxmExplorer III
DAS26miles wrote:
My brother says he has 2awg cable going from inverter to 2 BB Lithium batteries.
Try 00 ga cable for runs up to about 5 feet, bigger if farther. - 3_tonsExplorer III
DAS26miles wrote:
My brother now says he isn't sure if he has run the microwave off the generator now. He's been in full hookup CGs a few times. Not much dry camping since Covid. So the Honda 2200i must be able to handle the microwave. It's just the GoPower 1500w inverter. GoPower wants him to do some tests tomorrow and give them a call back. I will be able to check it out tomorrow afternoon at the CG. I have the devices to do so. I bet he has something drawing extra power from the inverter.
When trying, make sure that the onboard converter-charger is switched to off...
3 tons - DAS26milesExplorer IIMy brother now says he isn't sure if he has run the microwave off the generator now. He's been in full hookup CGs a few times. Not much dry camping since Covid. So the Honda 2200i must be able to handle the microwave. It's just the GoPower 1500w inverter. GoPower wants him to do some tests tomorrow and give them a call back. I will be able to check it out tomorrow afternoon at the CG. I have the devices to do so. I bet he has something drawing extra power from the inverter.
- jake2250ExplorerI run my 1000 watt micro with my Honda 2K,, I just tell the wife to not go over power level 8 when on the genny! Works just fine. Sure does go into high revs but she pulls hard and does the job.
Most places we go have an 8-8 geny hour. so with my solar I dont need it during the day, but for dinner we can use the micro and let the genny run for a couple of hours if needed to tip top off the batts if needed.
We do bring along some frozen prepared earlier meals for ease of camping. A few minutes in the micro makes a quick meal!
One tip,, I run True Fuel 4 cycle so no ethanol at all!! - KD4UPLExplorer IIThe inverter, with that load, will be pulling at least 135 amps from the batteries. #2 cable is marginal at best for a very short run. Larger battery cables should help some.
Is this a pure sine wave inverter or a modified sine wave inverter? If it's a MSW that may also be part of the problem, microwaves (and most other electronics) don't like them very well.
The Honda shouldn't have any trouble at all. - pianotunaNomad IIIHi,
The 2200 should power the microwave with ease.
When I had a 2500watt msw inverter it had a tough time running a dometic 1557 watt microwave. Some times I would have to run a small load (30 watts) to "wake up" the inverter before I used the microwave.
It will be interesting to hear the results of voltage drop on the BB batteries.
Are they wired in a balanced manner? - 3_tonsExplorer IIIA Honda 2000i will run it as will a 2200i...This assumes proper cable sizing to prevent the inverter from starving...FWIW, on another note a Lithium battery is not as sluggish as wet cells, and will result in very little voltage sag...I would opt for heavier cables...
3 tons - formerly having a Honda 2000i, 2000w inverter and 1500w MW, now with a more energy conscious 1100w MW and Honda 2200i - always 0004 ought cabling 7’ r/t length...
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
