Tom_M1
Jul 11, 2015Explorer
winnehonda wrote:I checked TVFool.com and there are two VHF stations close to you. WPTV and WPEC. You should point your antenna to 193°.
Have a 2015 Class C with Samsung TV and antenna booster. When I search for channels over air I can only lock in upper UHF channels. No 2-13 channels. I called Samsung and they got terribly confused about the antenna booster. When connected to cable I can receive all available channels. Any thoughts?
If you have a Winegard Sensar (Batwing) the arrow on the knob does NOT point toward the front of the antenna.
If you have a Jack antenna, the flat part of the antenna is the front.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
