winnehonda's avatar
winnehonda
Cannot get lower channel TV reception
Have a 2015 Class C with Samsung TV and antenna booster. When I search for channels over air I can only lock in upper UHF channels. No 2-13 channels. I called Samsung and they got terribly confused about the antenna booster. When connected to cable I can receive all available channels. Any thoughts?
  • Have switched from cable air numerous times. All I get are the higher channels, not the lower channels.
  • sch911 wrote:
    Have you switched input type from cable to antenna in the system menu? If not you should, then re-scan.
    X2
  • Have you switched input type from cable to antenna in the system menu? If not you should, then re-scan.
  • Have you already checked a website like antennaweb.org to find out which channels you should be getting?
