G_and_D's avatar
G_and_D
Cannot locate breakers and fuses
I recently bought a 1997 Gulf Stream Conquest and want to learn the electrical system. It is on a 1996 Ford E Super Duty chassis. I checked the truck manual and it says the fuse box is on the firewall drivers side, but I dont see it. Do I need to look from the inside of the cab?
I also cannot find the breakers for the coach. Looked in the bed, side of bed but nothing. I also cant locate the converter. There is a junction box beside the house battery which I have not opened yet. When I leave the camper for several days the house battery (new) looses charge so I must have a short some where.
Now for the real dumb question. The engine has 2 batterys one on the left and one on the right side of the engine. Why ??
Thanks for your shared wisdom.
  • Follow the shore power cord. It will terminate at the breaker panel. The converter is probably near that.
    You may have a short but all MHs have parasitic loads on the battery. Think CO and propane detectors. If you can't plug the MH in every few days you should probably disconnect the negative lead of the battery. The reason you should disconnect the negative lead is that there is a very real risk of causing a short circuit when using a metal wrench on the positive terminal.
    You probably have a single stage converter. That will take a long time to recharge the battery, think days. If you can only plug it in for a few hours the battery is not getting charged and thus will be discharged in a short time.
  • First question. The Ford fuse panel, for chassis only, has nothing to do with the house part, is located inside the drivers compartment, under the dash on the fire wall, same as most cars. On our 06, there is also a breaker and distribution panel under the hood near the drivers side fender.
    The MH part of the RV is usually one combined unit, 120v inlet, convert 120 to 12v for house and charging the house battery. This is usually a steel faced panel with flip open door. It will have circuit breakers for the 120v system (and main input breaker). The second part of the unit will have automotive style fuses for the 12v part of the MH.
    This could be located anywhere in the MH, but usually near the coach/house batteries. Our c-class also has a secondary panel for the house, which is located at the back of an outside storage compartment, behind another metal door.
    Two chassis batteries, quite possible if your c-class has the diesel engine. Our old Ford E-series based ambulance had 3 chassis batteries, two as you said plus a third under the left battery, accessed only by taking of the grill and headlight, the mechanics really loved checking that one.
    Beverley and Ken
  • Almot's avatar
    Almot
    Explorer III
    There may be no "short". Battery loses charge because there are devices that remain connected when everything is off, be it a truck or house battery. Good news is that they - usually - don't need to be connected when left in storage for several days. Take the cables off the battery, or at least, the +Pos cable.
  • Two batteries are probably your House batteries, the other is the truck battery.
