gjcummings
Jul 20, 2014Explorer
How old are the generators? I like Marcsbigfoot suggestion of float bowl issues. My EU2000i is ten years old and I just had to clean the carb - jets bowl etc. Check out YouTube. Prior to cleaning tough starting and stalling while under load after about 5 minutes...after cleaning carbs...zoom zoom zoom with one pull...as it should be. Check your plug also. Probably idle all day with bad plug but at speed (just had same problem with my outboard) ugh. Marcsbigfoot may be right as the brief hesitation causes the overload but not enough to stall out the gen then both gens go into overload.
I do like the vortex/lack of O2 not allowing enough air for a bad air/fuel mixture causing the hesitation or drop in RPM causing the overload...
Can't wait for the solution
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
