ktmrfs
May 17, 2013Explorer III
If you want/need a wider temp range adjustment dinosaur electronics makes a thermistor adjuster that plugs into the thermistor cable by the control board. Lets you adjust temp over a much wider range, or a dinosaur replacement ignitor board which has a built in potentiometer to allow you to adjust the temperature over a wider range.
otherwise, yup, sliding the sensor up and down on the fin is all you have.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
