hamel
Nov 19, 2017Explorer
enblethen wrote:
Make sure the electrode is adjust to about 1/8 inch from ground probe.
I'd tried this. I don't believe that to be the issue because like I said with the brown wire in a certain spot the sparker starts working. I can hear and see it sparking but with the wire configuration I won't hear the propane flap over and propane flow. If I change the sequence (currently the manuals) I got propane (can hear the flap open and flow) but the igniter doesn't try to work at all. I've emailed a mobile repair place for a quote on replacement. Not what I wanted but might be the only fix.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
