Old-Biscuit
Nov 20, 2017Explorer III
Correct wiring is:
Brown (12V DC from On/Off Switch)-----to/thru thermal fuse----to/thru T-stat---to TOP Connector on Control Board
- (2nd space on connector empty)
Blue (12V DC from Control Board to Fault Light)
Red (12V DC from Control Board to/thru ECO ---to Gas Valve Solenoids to GRD (Both solenoids have to energize for gas valve to open/flow propane)
- (5th space on connector empty)
Green (12V DC Neg/Ground)
Spark Electrode High Tension Wire connects to 'voltage transformer' on Control Board....sends 2000V to Spark Electrode to ignite propane
Gas Valve only has power to solenoids for 6-8 seconds WHILE spark electrode fires.
Trace the DC Path
On/OFF switch ---Brown wire to control board, then Red wire to gas valve
If you have 12V DC all the way to/thru gas valve solenoids then you should be able to 'manually' light the propane using a BBQ lighter.
Where are you placing Brown wire to get Spark but no propane??
Trace the DC Path
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
