enblethen
Nov 20, 2017Nomad
You need to identify the wire the blue leaves from the circuit board at the switch end.
The switch should have a wire that comes from the 12 volt DC positive, a wire that goes to the circuit board, brown input, the return, blue wire from the circuit board and a negative from the 12 volt system.
Added up that is four wires.
Look at page 7 of the manual, upper right corner.
Where did you get switch? It is the wrong one!
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
