hamel
Nov 20, 2017Explorer
enblethen wrote:
You need to identify the wire the blue leaves from the circuit board at the switch end.
The switch should have a wire that comes from the 12 volt DC positive, a wire that goes to the circuit board, brown input, the return, blue wire from the circuit board and a negative from the 12 volt system.
Added up that is four wires.
Look at page 7 of the manual, upper right corner.
Where did you get switch? It is the wrong one!
You know, I told my wife this. I'm thinking its the switch too! The switch that was in there I accidentally broke so I went to auto zone and found a three pronged switch that looked the same size.
Hopefully you read this and go, "DUH YOU IDIOT! GO GET A NEW SWITCH AT "BLAH BLAH BLAH" THAT'll FIX IT!"
LOL. Let me know what you think.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
