hamel
Nov 20, 2017Explorer
hamel wrote:enblethen wrote:
You need to identify the wire the blue leaves from the circuit board at the switch end.
The switch should have a wire that comes from the 12 volt DC positive, a wire that goes to the circuit board, brown input, the return, blue wire from the circuit board and a negative from the 12 volt system.
Added up that is four wires.
Look at page 7 of the manual, upper right corner.
Where did you get switch? It is the wrong one!
You know, I told my wife this. I'm thinking its the switch too! The switch that was in there I accidentally broke so I went to auto zone and found a three pronged switch that looked the same size.
Hopefully you read this and go, "DUH YOU IDIOT! GO GET A NEW SWITCH AT "BLAH BLAH BLAH" THAT'll FIX IT!"
LOL. Let me know what you think.
The switch I had before though didn't look like the manual one either though. The light is offset on the board not the switch like this.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
