enblethen
Nov 21, 2017Nomad
Your profile doesn't say where you are physically located. There must be competent RV repairman in your area.
I had problems with my gas valve ground that had me going for a while. I finally ran a ground from the circuit board to the ground connection on the gas valve.
Some salvage locations will have the harness for near nothing. Circuit board online should be less then $100.
There is that much more to the unit.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
