skipnchar wrote:
Can't help with the TV but All over-the-air television in the United States is broadcast using digital signals. There's no difference between a regular TV signal and a high-definition TV signal, or between a regular TV antenna and an HDTV antenna.
X2, Are you switching to an indoor antenna? You're much better off using the antenna on top of the 5er for signal reception. Plus all the cabling stays the same. If you want a different antenna due to performance issues, have you considered just replacing the antenna head?
