drifter_wayfare's avatar
Dec 11, 2016
Can't run a portable freezer on B&D battery station
I bought a small Whynter portable freezer from Home Depot. It requires 110V AC, draws a miniscule 79W and 1.1A. So I bought a Black & Decker 500W battery power station (Model PPRH5B) that has an inverter that can supply AC power to the freezer. I made sure that the battery capacity for wattage and amperage are above the requirements of the freezer. But as soon as I plug the freezer in the AC outlet on the battery, the battery fault LED comes on and the fridge doesn't run. The freezer runs just fine when plugged into a wall outlet.
I could've bough a 12V freezer than runs on cigarette ligher outlet, but they cost upwards of $600, meanwhile this freezer+battery combo only cost $275, except that it doesn't work...
Any suggestions on why this could be happening would be appreciated
  • the Danfoss dc compressor fridge
    usually a better job and use less power
  • MrWizard wrote:
    That's why the dang thing cost do much, it's the compressor and insulation
    very good.
    It'll do 'just as good' a job as a 120v one with higher wattage?
  • 2oldman wrote:
    That won't work well either, unless you have big thick wires feeding that outlet.
    The typical 12v Danfoss dc compressor, draws about 4 amps at 12vdc
    Aka 48 watts
    The avg 12 cig plug can handle this with no problems
  • As well as the current surge problem this would be a modified sine wave unit, which at best is much less effective with an inductive load (like a motor) and worst case will never work regardless of how much power it can supp!y.
  • As mr wizard said even if it did run it you would not get even an hour of runtime. More to this electrical stuff than you would think so it is best to ask the question before one makes purchases.
    Sam
  • Found this in the product overview.
    "Additionally, the 12 Volt power supply option allows for a wide range of applications from home use to field use to in-vehicle use."
    I looked it up on Home Depot - for some reason I can'd post a link, says the site is down.
  • It's simple
    79w is about 0.7 amps at 120v but that is 7 amps at 12v
    The killer is the compressor start up probably a surge of about 60 amps dc to provide 6 amps 120a.c. To start the compressor
    That's why I have a 1200w inverter to run my 100w residential fridge
    Compressor start is around 900w
    Even if you got it started you would only get an hour or two of freezer run time
    It's going to draw 7 amps from the battery while running
    I doubt that battery is larger than 10 amp hrs
    Your not the first one to miscalculat 120v power use to 12v power
    You won't be the last one either
    You might be able to return the battery station
    Put that money toward buying a 600w inverter, that is 600w continuous 1000 surge, you need to be able to hold that 600w until the compressor spins up and is running, were taking one l or two seconds
    Not milliseconds that most inverter surge ratings are
    Connect that inverter to your RV batteries
    That 500w connected to a small battery won't work
  • The inrush (start up) current draw for a compressor based refrigerator/freezer can be considerably higher than the running current draw. You need more inverter. Most likely in the 1500W to 2000W range to start the freezer.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 06, 2025
