rk911
Jul 30, 2016Explorer II
Mmwtdh wrote:
Shorter cord would help and larger gauge cord would help. You're running out of juice due to resistance loss.
that and if you're plugging into a standard 20-amp wall socket it's likely that the amp-pull from the AC's compressor combined with whatever else is running is tripping the circuit. can you disable anything else like the battery charger side of the converter, inverter, res. fridge, etc. (if so equipped)?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
