cbshoestring
Jul 30, 2016Explorer II
smkettner wrote:cbshoestring wrote:Similar adapter is used on thousands of RVs on a 240v/120v 50 amp RV site every day.smkettner wrote:DO NOT DO THIS. Electric dryers are commonly 220volts, your trailer is 120volts.
Do you have a dryer outlet with a 14-30 outlet? Could make an adapter.
Just the neutral pin is different on 14-30 vs 14-50
The electricity is the same.
I have a 50amp to 30amp adapter that I have used at many CG's, but I have never seen a 220volt to 120volt adapter.
Are you suggesting they make a simple adapter that reduces 220 down to 120, that would allow you to safely plug in your RV.
I have never seen a CG wired for 220, I will run from such a CG if I see one...cause my limited knowledge tells me that even a 50amp RV is dual legs of 120...NOT 220 that dryers require.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
