time2roll
Jul 30, 2016Nomad
cbshoestring wrote:You need to look up how to wire a NEMA 14-50. This is the same connector your home uses to drive your 240 volt electric oven or range.
I have a 50amp to 30amp adapter that I have used at many CG's, but I have never seen a 220volt to 120volt adapter.
NEMA 14-30 is exactly the same except the neutral pin is an "L" shape and can be adapted same as your 50-30 adapter works.
Please do some additional research before you start blasting nonsense.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
