pianotuna
Feb 02, 2015Nomad III
Hi Gordon,
At least one person is having trouble with a Magnum 3012 and load support. It is behaving differently and acting as if it were a non hybrid.
GordonThree wrote:
The Magnum has a 125 amp charger built in. With one yammy I get about 85-90 amps at 13 amps input. Problem is, the Magnum's "brain" doesn't tolerate heavy loads cycling, even if the internal charger is shut off. It doesn't wait for the yammy to spool up when the dehum. compressor kicks in, instead it disconnects the generator and switches to battery.
The hybrid Magnum's brain works differently. Instead of disconnecting the generator, it kicks in extra juice from the batteries, until the generator can carry the load completely.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
