GordonThree
Feb 02, 2015Explorer
pianotuna wrote:
Hi BFL13,
Since I can run the 125 amps in the PF corrected Magnum with 924 watts of electric heaters, plus fridge, plus 50 watt heating pad from a Yamaha 3000 sIEB, I don't think there will be an issue with a Yamaha 2000 VA running only a 100 amp @ 12 volts PF corrected load.
I have not seen my Magnum go over 90 A running off a single Yamaha 2000, with the load limit set to 13a. Running two Yamaha, 3200 effective watts, 125 amp max charge rate is no problem.
That's a bummer folks are having trouble with the new hybrid 3012
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
