pnichols
May 13, 2015Explorer II
BFL13 wrote:
Your test did show the batteries still work quite well though.
That's how I interpreted the test results. I was thinking about replacing those old timers just in case, but will probably hold off now. I guess that 24/7 on float for years between trips is paying off.
Before an Alaskan trip maybe next year, I'm thinking about installing some roof solar ... using a 24V or 36V flex poly panel but mounted slightly up off the roof for cooling, using 3M VHB bracket-bonding to the fiberglass -> so no holes, with an MPPT controller mounted out of the weather down at the batteries.
Maybe for Alaska I should have both the solar and new AGMs?
