jrnymn7
May 16, 2015Explorer
It might be interesting to compare similar Capacity tests on String A and String B? And maybe even switch batteries around, and do an A1/B1 vs. A2/B2, and an A1/B2, vs. A2/B1.
I did rotate the bank 90 degrees, recently, but I kept A1 with A2, and B1 with B2. So the only difference is which batteries the Pos and Neg leads attach to.
But I also added two bus bars, and the short leads that attach them to the battery terminals. I can't help but wonder if this has added to the bank's self discharge rate???
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
