jrnymn7
May 17, 2015Explorer
NinerBikes wrote:
Perhaps your charging loses were greater than 4% to recharge? Your charging losses will be greater as you approach a 100% SOC. Takes a lot of losses to get that last 3,4 or 5% back into the battery, just due to battery chemistry, and not a lot of sulfur sitting on the plates to put back into solution.
It's good to let your solar panels take the hit late in the afternoon for those charge losses to top the batteries off, instead of your generator burning a bunch of gasoline for a whole lot of nothing being added.
Niner,
Yes, it definitely appears the Trimetric is not allowing enough for losses. I will keep an eye on that, and recalibrate, if necessary. A few more cycles should tell me either way. And yes, I'm very eager to get the solar going. Hopefully over the next few weeks.
Did you ever sell that portable set-up?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
