jrnymn7
May 27, 2015Explorer
I have yet to see any evidence that high current "speed" charging causes decreased life expectancy. It seems, as long as voltages do not far exceed gassing voltages, the battery will not be harmed. But as you say, even a 15% drop in cycle life would be a worthwhile trade off. Up here, gas is about $5.20u.s. per u.s. gallon. A 4 hour (top end) charge, (just to replace a measly 50-60Ah's), using the Honda 2000 and a 45a charger, costs about $2.60u.s.. It doesn't sound like much, but those tables in the article really put things into perspective, efficiency wise.
on a different note;
I used the microwave this morning, and I paid close attention to what the various meters had to say regarding wattage, amp draw, and Vbatt. Until recently, I thought the xantrex prowatt 1000 inverter's wattage reading was way off, but now I realize it was due to significant line loss. The amp draw seemed way too high for a 1080w draw, but I recently realized I was ignoring voltage drop. It turns out, Voltage out of the inverter was dropping to less than 100v. 1080w / 11a = ~98v.
But what really caught my attention was the discrepancy in Vbatt readings, while the MW was running. Bank was at ~93%, -29Ah's, 12.77ocv. According to the multimeter, Vbatt dropped to 11.81v, but according to the inverter, Vbatt dropped to less than 11v and shut down, about 2 minutes in... much to my surprise. After about a 5 minute rest, during which time the inverter's fan ran full out for the most part, I ran the MW for an additional minute (bound and determined to have scrambled eggs), with no (~11.5v)alarm or (~11v)shutdown. Turned off inverter, and 20 minutes later, Vbatt rebounded to 12.76ocv. So bank had no problem handling the load, it seems.
BFL mentioned toasting an inverter, but I'm not sure if it was the xantrex 1000??? This may be a sign to stop pushing the unit so hard with the MW; even though it is supposed to handle much higher peak loads for up to 5 minutes. I'd love one of those inverter MW's but they're physically too big, even the 800w models. A 600w MW might work, if such a critter exists? But for now I'm gonna try using 'power 80', and see how that goes.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
