jrnymn7
May 29, 2015Explorer
Did a 65-100% last night. Pm went into float after about 8hr-40min. Before float, Trimetric said well over what was removed, Ah wise. But when the pm shut off for a few seconds, while switching gears, the Tri's readout zeroed out and started counting upwards, again. This does not happen when the pm shuts down after its 15 minute boost thing. Perhaps it only zeros out over 100%?
The default efficiency setting (P10) is 94%, so I changed it to 90%. But I'm guessing it's accuracy will be largely based on how deep of cycles I do from this point forward? It touches on this issue in the instruction manual, actually.
I thought if you changed amps to watts (P4), the meter would track watts in and out, but it does not. So I don't see the point of it showing loads in watts, if they are not kept track of by the meter? In the end, it still about Ah's in and out.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
