jrnymn7
Jun 03, 2015Explorer
BFL,
Is that 72% according to the trimetric? I know your P10 is off a bit. Just changing P10 on mine, from 90% to 86% eff, made a huge difference in when amps appeared to taper... 89% soc vs low 80's, at a little under 14.4v.
72% is 128Ah's missing, whereas -103Ah's would be 77.5%, so a slight tweak of P10 would likely line things up... not that you need to concern yourself with that, but it is interesting to see how P10 plays a role. The manual points out that the 94% eff default setting is likely too high, and that 80-90% is more likely the case. Looks like I'm right in the middle of that, doing 70-99% cycles.
I've been wondering if the vector style profile is playing a big part in the numbers I'm seeing? Would the standard cc/cv profile give similar results??? And I don't really know how the pm3 is going to behave after being modified... I'm guessing the same as the pm4b? Does your 100 amper have a vector style profile, with volts rising throughout the entire charge? ( And I don't remember if that one was the one you modded?)
(btw, trying out my first solar run, today.)
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
