- rockhillmanorExplorer IIThose alarms are also hard wired to the 12 volt side of your RV.
Beeping means 'low voltage'.
Check your coach battery. - texascatsExplorerMy goodness, what a great forum site this is! To those of you who replied, I do so appreciate the advice. I didn't know CM units needed replacing. I thought it was just the batteries. Thanks again.
- aruba5erExplorerBuy a new one
They only have a 5 year life and that may include shelf life Not that expensive considering your life. Whats it worth? More than $15/18 bucks? Plus the fact that in an RV it's exposed to more CO than in a home because of the travling on the highways with all the other fuel burning stuff out there - Get a new one.
- Dennis12ExplorerIf the replaced batteries are good just remove the CM.
- Beverley_KenExplorerCheck the expiry date. Yes they du expire and will beep and alarm when its time to replace..
Ken
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
