path1
Jul 24, 2016Explorer
Carbon monoxide alarms fuse and batteries?
Time to change out alarms. Propane alarm, fuse at converter, Smoke alarm, 9 volt battery inside alarm. "RV carbon Monoxide" alarm not so easy to find the fuse.
I can't find the "one amp" fuse. I found where wire connects to house battery, but don't see any fuse. Pulled alarm out of where its mounted, don't see any fuse there. The alarm is one piece plastic, fuse can't be inside, unless manufacture put it there. But the manufacture says fuse is in wiring to battery.
The wire from the house battery connection, I can see about 16 inches then the wire goes behind a wall. Wire from the alarm side, I can see about 1 foot, but don't see any fuse.
Maybe I don't have to find the fuse?
Questions...
1. Any short cuts to finding where fuse is?
2. Anybody know of any alarm that work off from their own battery (9volt, AA, etc) instead of 12 volt? If so, I'll just swap it out.
http://www.mtiindustries.com/PDFs/rv/65_Series.pdf
Thanks
Questions...
Thanks
