SaltiDawg
Nov 20, 2013Explorer
Dutch_12078 wrote:
CO detectors are not affected by freezing temperatures, but residential detectors may not reliably withstand the vibrations related to RV travel.
Dutch,
Just looked on line. Most, if not all, residential CO Detectors that I could find had a limit as to both low and high temps... typical Low limit was 32 or 40 degrees... however some were down much lower than that.
I don't know if you are correct, however I would look at the manufacturer's lower limit before purchasing.
I also don't know what the low ambient temp limit is as far as the detector batteries... if battery powered.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
