usolm1's avatar
usolm1
Carrier combo A/C and furnace.Help,this is a boat on wheels
I need your assistance, I have a Carrier V Air system in my 2005 Damon intruder Motor home. This is a combination system where the remote works the a/c and the furnace. I have two A/C units. The rear works on generator but not when plugged in. The front and the furnace stopped working all together. I was running the front on generator over the weekend ,shut it off and next thee generator. Ten minutes later, the furnace comes on along with the front a/c. I did smell something like burning wires. I shut the breaker and pulled the fuse. any ideas as to what to look for. I called carrier and they don't make that unit anymore and had no support at all.
tanks in advance,
Lou
  • thank you for the advice and wisdom, I will start with that.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    From the sounds of it the control board may be toast.. By the way all is not lost.
    On this system the ONLY thing the A/C has to do with the furnace is a single relay, this relay replaces the contacts on a thermostat, it turns the furnace on and off (NOTE the rear control system has this ability as well, it's just not wired in to the furnace since the wires go to the front.
    Now here is the problem. The problem might be fixable, A full visual inspection of the control board and the wiring in the front unit may yeild joy
    For testing: Go outside, access the furance from outside you may find a switch (Really a circuit breaker) on top of the blower housing.. TURN IT OFF, this kills the furnace (yippie).
    Now you won't have dualing HEVAC systems, Restore power (12 volt) if the wires look good. inspect all the wiring and traces.. Good chance a relay is the culprit.. Theory has it you can find replacements for those..
    If worse comes to worse you can try and find a new Carrier Air V control board, or a used one on E-bay.. Failing that I will have a spare come tomorrow.. However I really do not wish to part with it, I plan on keeping it just in cuss my other one goes bad.
  • I was running the front on generator over the weekend ,shut it off and next thee generator. Ten minutes later, the furnace comes on along with the front a/c.
    Please, explain how this is possible without a secondary connection to shore power. If that was the situation, most likely suspect of electrical smell may be the transfer switch.
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 13, 2026
