jplante4's avatar
jplante4
Explorer II
Sep 23, 2016
CAT Service
Just a note to my northeast neighbors. I took the Sahara to Milton CAT in Milford MA for a scheduled valve adjustment on the 3126. While it was there, I had them do the lube and oil service and replace both drive belts. They went above and beyond in service, even giving my valve cover a brand new coat of CAT yellow. The service manager Jose is a great guy and treated me very well. We had a miscue in when to pick up the bus that resulted in an extra 2 hours drive for me, so he knocked off a few bucks on the shop rate.
It's tough to find a truck shop that will work on a motor home around here. The RV place does ok work but for this CAT specific maintenance item I though a CAT shop would be best.
The tech went through everything underneath and found some suspension stuff that needs attention. I figured there was something up because I've been hearing some squeaks lately.
He also recommended a 195° thermostat (the coolant temp is running just above 170° which I thought was good). I'd be interested in hearing opinions on this from the diesel gurus here (Brett).
  • Reference the question above on optimum diesel engine operating temperature, at one time I worked for a public transit system and had the job of researching technical information and writing the specifications for new equipment purchases. At that time, 195 degrees was the optimum operating temperature for a diesel engine, since the laws of physics do not change that temperature should still be optimum - thus the recommendation by the Cat technician. We purchased thermostats, cooling system components including radiator shutters in order to maintain 195 degrees as consistently as possible.
  • I have the same CAT engine in my 2001 Beaver coach. That temp is very good....mine has always ran at 182 for a coolant temp. I took my DP to my local CAT service for convenience because its only 15 minutes away from home. It turned out to be a huge mistake on my part. A few things to have repaired and it turned into a 3 1/2 month screwup by them. Then they tried to be dishonest and not admit their errors until they were caught red handed.Then they had to admit fault!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
