mockturtle's avatar
mockturtle
Explorer II
Apr 24, 2013
Catalytic heater install
I just bought an Olympian Wave 6 catalytic heater along with the necessary accessories. It's going to remain portable, rather than built in, so I just need a tie-in to the propane line under the stove top. Here's the problem: The local RV service center won't do it and I don't want to attempt it myself. Would a propane company be a better choice than an RV service facility? Where would I find a 'qualified installer'?
  • I will stick solely to the OP's question...
    It makes sense to install a propane shutoff cock valve near the junction of the feed line to the heater. I am very, very touchy about what kind of supply line I use for the heater. Routing the line so it doesn't get in the way is one of my primary objectives. I have had to have custom LPG hoses made up with crimp 90 degree elbow fittings at a hose place in order to make a clean and neat installation.
    Best of fortune with your installation. You're going to love it! The pot bellied stove effect on a cold day is priceless!
  • Oylmpian CAT heaters require minimal venting. The first RV I had one in was so leaking I didn't bother. (an ET-8100, electronic ignition with thermostat, I don't think they make it any more)
    Do they not want to install something you didn't buy from them, or is it putting the heater in any rig?
    I would not think a propane firm is the right choice. There are many (MANY) RV services places in the area, even a few mobile ones. I'd keep looking.
  • ...and if you plan on using it inside how do you plan on venting for the heater?
