eHoefler
Mar 06, 2014Explorer II
It is putty tape. You stick it to the window mounting flange, then install the window tightening the screws evenly until all are snug. Then trim of the excess that has squished out, can be quite a bit depending on the smoothness of the outer skin of the trailer. Then run a bead of caulk all the way around the window.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
