LarryJM
Mar 08, 2014Explorer II
Pirate wrote:
Here is another great tip. Get some foil tape and tape over the window opening from one side to the other. This will make any water intrusion roll away from the opening and to the outer walls instead of running down in between the wall sides.
That is a FANTASTIC idea and a great way to be 100% sure that any leaks won't get inside the walls as long as the screws don't penetrate the actual walls of the trailer which a lot of the newer ones don't.
Larry
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
