deepdoc1's avatar
deepdoc1
CCC2 Thermostat Question
Just got new Penguin 2 Heat pump and CCC2 thermostat installed and having a learning curve moment. I'm currently driveway camping and not plugged in. When I tried to turn on just the furnace, the heat pump also came on. I tried to change modes to furnace only, but heat pump still comes on. That will kill my batteries in short order, so how can I get the furnace to come on by itself? I checked the manual, but all it refers to is the default aux heat mode of heat pump then furnace. Any help?
  • deepdoc1 wrote:
    Ok, that seemed to work. Fan spped was Med, so set it to auto and overhead fan turned off, leaving furnace on as desired. Thanks!
    It is ALWAYS amazing what you could learn, IF YOU JUST READ THE OPERATORS MANUAL, for the various appliances in your RV:B Doug
  • Ok, that seemed to work. Fan spped was Med, so set it to auto and overhead fan turned off, leaving furnace on as desired. Thanks!
  • Yes, I got the 2000 watt inverter installed in Quartzsite and it runs the whole coach. I am quickly learning to leave things like the AC, water heater (AC), and microwave off when not hooked up. I am open to having a sub panel put in if I can't make myself behave.
  • Good catch! I just ass-u-me-ed it was the heat pump, but it very likely was just the fan. So, if I get the idea, I should have the thermostat in furnace mode and the fan in auto and that should allow the furnace to come on by itself?
  • Make sure the fan mode is set to auto, otherwise the blower will run even when FURN is selected, I believe.
    Interesting that your rooftop heat pump is wired through the inverter though- not usually done that way.
  • Are you sure it is the heat pump and not just the A/C fan? It is a well known problem with the CCC2 (actually documented in the manual at one time) that the Fan should be set to "Auto". Any other speed causes the A/C unit fan to run
