docj wrote:
sdianel wrote:
I use the Wilson Sleek and got the window mount suction cup mount and a taller antenna. I put the antenna on the inside of the window. Place the phone or wi-fi hotspot on the Wilson Sleek. Worked for me all over the US. If I get a weak signal I can boost it enough to make calls and get online. Is it real fast? No. But works for me and price is reasonable. I ordered mine from Walmart.com
In most situations there is absolutely no relationship between the speed of your connection and the strength of the signal. Amplifying a signal doesn't "make it faster". The only way a cellular booster can provide additional speed is in those situations in which a 4G signal might be too weak to reliably connect to so the phone would go to 3G without an amplifier. But in normal use, the amplifier simply provides a stronger more stable signal. So if your Wilson Sleek works for you, the chances are that a more expensive amplifier would not produce any better result.
From the user standpoint, this is not the case.
I will concede that strictly speaking (at the physical and data link layers) this is true. The data rate at the Physical and data link layers does not change. However at the upper layers of the stack (like the network and application), the "effective" data rate can, and usually does, drop off at at lower signal strengths. At lower signal levels you get more dropped/corrupted packets. The upper upper layers of the stack (like network and application) must request re-transmission of these packets. Thus effectively (and at times significantly) reducing the effective (which is all the user cares about) "speed" of the connection.
It is true that amplifying a bad signal just gives you an amplified bad signal and will result in no increase in effective speed.
Additionally, this statement (no speed increase) does not consider one of the key factors of a good signal booster:
1) The antenna for the signal booster is usually placed in a position that it is getting a much better signal (like on the roof), than would be present at the antenna of your cell phone (in your car or RV). Hence it is receiving a much better signal to start with.
2) The antenna on a good cell booster is much more sensitive that the one on your cell phone. hence it received weaker signals and eliminates many of the errors/corrupted packets due to low signal.
Sorry if I jumped into lecture mode, I have a Master of Science of Electrical Engineering, specializing in communications...this is what I do for a living....this is probably way more info that was needed...
