Dave_H_M's avatar
Dave_H_M
Explorer II
Jan 02, 2018
Ceramic Tower Heater Woes
I have the above heater that I use as a supplement heater in the winter in the fifth wheel. It is digital and has an on board thermostat so you can set the heat and let it work automatically.
Out of the clear blue, the controller went south. Now it just runs on the high setting with no thermostatically control over the heat.
So is there anything to try before taking the fan out and tossing ldthe rest? like love taps or something similar. :R
  • Wait'll
    "discovers" just how "evil" recreational vehicles are. All depends on whether or not the length of his attention span shortens. The picture does this justice.
  • Mex, you cant use the words Resource Depletion on here, this is an RV site, the epitome of resource depletion!!!!! :)
    I was near the Imperial dunes and watched the New Years crowd heading home in a constant stream of jacked up fuel guzzing 4x4's pulling tri axle TH. I was passed by motor home after motor home pulling huge enclosed trailers or tri axle stacker trailers. We dont have energy problems and we sure dont have any environmental concerns. ZERO. MORE MORE MORE :) BAAAWAAAAAAAA
  • Idiotic resource depletion wins every time...
    Anything labelled SMART is likely something BROWN as far as value is concerned.
    Can you UNPLUG the heater, turn it upside down take off the cover then take some close-up images then post them?
    If a radiant heater, care must be taken when modifying so as to not bypass the tipover safety switch.
    A LINE VOLTAGE DIAL THERMOSTAT CAN BE USED but it's going to sit on the floor where all the cold air resides.
  • Throw away junk but while it's doing it's part at being junk set it on something like the open oven door so it doesn't burn the rig down if it goes into melt down.
  • If you haven't already, take an air nozzle to it and blow it out. Mine was totally plugged with dust when I took it apart. It's still broken and since replaced, but if I would have blown it out every so often it would still likely be running.
  • ken56 wrote:
    Usually these things are throw away items and not worth the cost of fixing. You could look on line for a replacement stat/controller or call customer service if there is a number for them, then they would just send you to the nearest service center. Easier to just go shopping.
    X2
  • good idea Gordon. I already have an inline thermostat on the heater in the fake fireplace. Don't know if it practical but will ponder that.
  • Usually these things are throw away items and not worth the cost of fixing. You could look on line for a replacement stat/controller or call customer service if there is a number for them, then they would just send you to the nearest service center. Easier to just go shopping.
  • Will it turn on when you plug it in, or does it default to off?
    If it comes on, you can use an in line thermostat on the power cord.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
